1 - 8 of 8 Posts
Mine was leaking out of the return line. I bought an pre made line from summit with an fittings. I'll look through my paper work and post the part numbers.
If you search for vortech return line you should find some info.
This is my first supercharged setup so bare with me. Unless I'm thinking about this wrong, how could the return line be the issue when oil is puddling up around the discharge of the blower? The return line doesn't even look like it's leaking oil.
In your 2nd picture, is that looking from the top down?
If so, there looks to be oil on the top of the hose.
I suppose if it was a blower seal, the pressure could force it through that joint.
The fact that the metal of the blower seems dry, but the hose is wet could also support that theory.
Also, in that same picture, the bracket on the left appears to have some oil on it.
Where's that coming from and is that the source of your leak and it's running down the blower?
1 - 8 of 8 Posts
