I went to the track on Saturday and I turned the boost up on my car. I race a 9.50 index class but I have always wanted to go 8 seconds so I cranked it up and went 8.95 so pretty happy about that in 90 degree weather. I usually 60 ft in the 1.35-1.30 range but it spun pretty bad. My question is I noticed at the end of the track I could feel some vibration in the car is this normal? I have Bias-ply tires and they are balanced. Should I rotate my driveshaft? Just not sure if I car should be like that it did it on both passes right at then end probably like over 145. It does not do it all until then.
maybe the tire has rotated... are you marking them?
i'd also check the driveshaft bolts, motor mounts and re-torque the wheels
Vibration
I checked the wheels they are 115 ft/lb on the back and 75 ft/lb on the front. I did not mark my tires I can check that to see if they have moved. I have them high tacked but could have moved. Ill check driveshaft u-bolts on the flange in the back. Could a bad U-joint cause this you think? Or would it start at a lower mph? Also I will check motor mounts tonight and I will check cross member bolts.
