1 - 12 of 12 Posts
Launches like a mofo.
that car is violent off the line! nice runs
Very nice, nothing like a 9 second street car with a manual trans. Congrats
VID REMOVED.......... REHOST PLZ
Either inappropriate or the video sucked? Interesting.
Done!
Harsh:shakehead
I deleted it because I was going to add a few more clips to it, but have not got around to doing it.
I added the youtube version of the vid to the first post.:idunno:
I hope to improve on the times next week. The weather will be a little better, hopefully the track prep is atleast as good (I pulled a 1.43 60ft on the last run:evilgrin:)
Discussion Starter #12
Thought about doing this to my '96 Cobra. Need some details.
What's your car geared? How much boost? How much power is it making?What octane gas are you running? Any weight reduction?
3.55's
25psi
no accurate dyno numbers at 25psi (made 598 at 18psi and ran a 10.59 @ 134)
110leaded on 25psi race tune (93 oct on 18psi street tune)
Some weight reduction (still has cold A/C, P/S, hydro boost, in dash 6 disk)
Here is i can think of:
GT brakes (deleted ABS)
15" draglites (15x3.5, 15x10)
QA1 tubular K (stock fox A arms and stock style moroso drag springs)
no ft sway bar
Kaenen fiberglass Cobra R hood
no rear mach 460 amp rack/speaker box
Track only: I remove the passenger and rear seats (probably 80-100lbs)
I have not had it on the scales, but I think that my race weight is probably around 3500-3550 (I weigh just under 200lbs)
It still has an Iron block. The teksid blocked engine that I am building will offset the weight of the chromoly 10 point cage that I NEED to install.
1 - 12 of 12 Posts
