Would I lose lots of power on the low end with a Vic Jr Intake and my setup. It's mostly a daily driver for 9 months a year. I'm afraid that the Vic Jr is gonna take power from my 4500rpm and lower. But I also feel like the high compression motor , Turbo and 3.73 rear will compensate for the shorter runners on the VIC JR. All opinions welcome
4.75 Stroker MMR 750 10.5 to 1
Built 4r75w 3600 stall
Snow Methanol kit
On3 FF single kit with a Precision 7876
Ported PI Heads
Stage 2.5 CMS Turbo Cams
Returnless Cobra Fuel Tank Twin 320 Pumps Modified FPDM
60pd Injectors
3.73 Rear end
With those cams, and your turbo, when do you expect it to really start to spool up? If the cams / turbo aren't going to make power till higher up anyway, the Vic intake might not hurt you, especially with 10.5 compression. Was a turbo an afterthought?
^ I agree. Those gears and that size turbo on these motors would have more of an effect on your spool time than going to Vic Jr. at this point
