1 - 10 of 10 Posts
So I got an '87 LX Vert. It's a partially complete V8 swap. Previous owner has an 8.8" swapped in, Lincoln 11" brakes up front, A9P + harness, Eibach Lowering Springs, Rousch shocks, and that's about it... I am putting in a mostly stock 5.0 for now. It was a standard 302, but I converted it to HO on my rebuild and ported the E7s... I plan on getting longtubes for it as well though.
The front is 5 lug swapped... but the rear isn't so I need to do that sometime. But this car is a vert, so I know it's a bit weaker then most... Anything I should do to stiffen that up, or will it be ok on a mostly stock engine?
What type of tires should I get for decent launches?
k, thanks. I am looking for something that will last about 20k miles, with occasinaly burnouts... lol
Ok, yeah, sub-frame connectors don't cost a whole lot really. I'll probably browse chitownracing for wheels and tires when the time comes this summer.
Any other suggestions for the car?
The other thing that came to my mind, with the stock internals of the tranny and 28 spline 8.8" dif, the sticky tires will be safe to run?
Your axles will need to eventually be upgraded. How soon? That's a tough one. Some have gotten away with stock axles, a stick, and high rpm launches on slicks forever. Others like myself broke an axle with a mild 12 second combo in short order. Yet others have broke 'em on a mostly stock 13 second ride.... I'd replace 'em before I ran a slick; maybe even before I ran any sticky radial too. The diff can be cheaply upgraded with a junkyard Explorer rear diff. It uses the same clutches; but the pin & side gears are much larger. The trans can take some abuse; the question is what clutch you have & it's current condition....;)
Ok, thanks, I'm not sure how sticky a tire I plan to run. Probably not much... So I'll use the 28 splines for awhile, then upgrade to 31s down the road...
1 - 10 of 10 Posts
