1 - 8 of 8 Posts
Hey guys, I have a TFS 1 cam with a on3 kit now installed. The car is untuned but I need to get it running decent so I can take it to the exhaust shop. Timing is set at 10 degrees and fuel pressure at 38 at idle. I also have a manual boost controller hooked up to it.
What should my vacuum be now at idle? I am showing 6-7 that's it. When I had it out on the road under cruising conditions under no load the car would run 20-21 vacuum. Any info helps, thanks.
I'm running 12-14 inches of vacuum with a FTI cam and S Trim. It's possible you have a vacuum leak somewhere. I would inspect all vacuum lines first. You will always be in vaccum when not in boost.
Weird you post this. Sorry to hijack thread but I put my car back together today, after HG's and my boost gauge sits at zero not instead of 6-7 at idle. Car is idling at 2k and is lean. I wonder if I have a vac leak too? It is a carbed car. Only thing I changed is I had my wastegate hooked up wrong (boost line in top not on bottom)
Sent from AutoGuide.com App
I am pretty sure there is no vacuum leak it is running really rich though around 11.3 or so at idle but it has not been tuned yet.
What are your idle rpms. If idling low and fat can cause low vacuum at idle. Try turning idle up to 800-900
What others have said but sounds like you have an issue some where.
I have the TFS 1 cam with a turbo and at 825rpm mine pulls about 10-11" once warmed up, which I feel is about normal. Leaning out the idle will help, but I would be hesitant to say it would completely fix the problem.
Good luck!
1 - 8 of 8 Posts
