What's the biggest difference between both kits, I know SCi advertises 5-6psi and the SI advertises 8-10psi... how are they different, I thought both head units were exactly the same?. Exactly what pieces would I need if I were to start with an sci and eventually want to make more boost?
I currently have a 306 with HCI on stock block. My goal is 420-450 rwhp and as funds allow, eventually upgrade short block and be over 500rwhp. Should I just wait and pull the trigger on the SI kit or start with the less expensive sci?
Sorry if this is a dumb question, I don't have any experience with centrifugal superchargers - thanks!
Sci trim is a base model trim to start with that starts at 5-6lbs of boost and plastic discharge pipe with no bov used. It is good for up to 725hp at max boost i believe. Once you reach 8lbs of boost you should upgrade to an aluminum discharge pipe and bov. The Si trim is a step up and considered a high out put setup that comes with an alumnium discharge pipe and Bosch bov starting at 8lbs of boost with hp up to 775hp at max boost.
Take a look at the Paxton Novi 1220. Its the same sci compressor but is true 8rib out of the box. I went 10.70s 128mph on a HCI 306 using the stock 6psi pullies. Its a badass little blower. In my opinion it's a great compromise between the vortech sci and SI.
I would go with the SI. It will be cheaper to pulley the supercharger bigger to reduce boost now than it will be to upgrade the unit later down the road.
I'd go with SI trim. Run the stock pulleys for now and will you build a better bottom end swap the stock 6.87 crank pulley for an 8in renegade pulley
