maximum motorsports told me it was okay to use the stock fox booster with the 94-95 cobra 15/16 bore mc. is this true? i always thought that i had to do the 93 cobra one?
im running the 10th aniv. cobra calipers front and rear.
It's perfectly fine. I use the factory '88 booster in my AI car.
All the booster does is determine the pedal effort (not the pedal travel.) If you set everything up and the effort is too high, you can install the larger Cobra booster if you like. I like a hard pedal so I stayed with the smaller Fox booster.
and the 15/16 94-95 cobra master cyl is what i want for cobra calipers all around?
Probably.
Ford initially went with a 1" master cylinder on the '93 Cobra R. Some folks complained about the hard, short pedal so they changed to a 15/16" master cylinder to give a little more pedal travel and a slightly softer pedal. Most folks seem to like it.
I stayed with the harder pedal.
