I bought used "3.55's", but am starting to think they may actually be 3.73's.
My car: Stock 16's, 245/50/16 tire, 5 speed ... and I just went to the track for the first time and finished at ~102mph at about 4900 rpms in 4th gear.
What do you guys think?
According to the corral tech calc., w/ 3.55's I should be around 4750 rpms and w/ 3.73's I should be around 5000 rpms. Is there any other way to tell?
Thanks,
Andy
hey hey
pop the cover off the diff, count teeth and do the math. Divide the number of ring gear teeth by the pinion teeth. Then you'll know for sure.
put you car in the 1:1 gear. i'm not sure, but i think it's 4th for 5 speeds. then go 80MPH and what ever RPM you are at is what gear ratio you have. if it is closer to 3550 then it's a 3.55 and if it's closer to 3730 then they are 3.73.
EASIEST WAY!!!
jack up the back end.
spin the drive shaft until the tires make on complete rotation.
if you have to spin the drive shaft 3 and a half times = 3.55
if you have to spin the drive shaft 3 and 3/4 times = 3.73
same here
Yeah I had the same kind of question because I thought I had 3.73's but the corral tech calculator said 4.5's. That seemed slightly extreme. I've yet to procure a jack to do the wheel spin trick, though.
