1 - 12 of 12 Posts
I'm thinking of going with a upr Kmember kit but trying to figure out which spring rate would be best suited for my car. Its a HCI single T70 that makes a little north of 500/500. I will be running 90/10, 50/50 and eibach drag launch springs in the back with an airbag. I just weighed the car and it weighs 3100 lbs. The car will be used for mostly street use, but I race quite a bit. I'm leaning towards the 12" 200 lb spring. Any advice/input appricaited...
i went with 14" 175's and my car is heavier... youre car could get away with even lighter springs
that 12" spring is gonna be more of a street spring.
i use 14" 200's and 90/10's
drives fine
I believe I read that Team Z was experiementing with 12 inch spring with good luck at the track.
It depends on what type of spring you'll be looking for, from a street standpoint are you
A. looking for a handling spring for the street.
B. looking for a weight transfer spring for the street.
Pat
UPR Products
i run a 14/130 drives fine on the street.
double post
UPR talked me into the 175lbs springs the first time around. Get the 130lbs springs. It drives on the street just fine and it makes a difference at the track.
Discussion Starter #12
The car will be mostly driven on the street, but I'm not afraid to sacrifice driveablility to make the thing hook on the street/track...
1 - 12 of 12 Posts
