Guys I just finished installing upr pro coilovers and qa1 12-150 springs with Lakewood 90/10 I used the upr 4 bolt cc plates as well. I got the fox struts due to being lower....instal went good but when I go to adjust the caster positive (all the way back toward firewall) and the camber positive (all the way pulled out towards outer fender) the spring will interfere with the nuts on the stud plate from underneath is this normal?
Discussion Starter #2
Bump
