Upgraded my Autometer Sport Comp gauges with LED bulbs a few weeks ago and after blowing a fuse due to a short, I replaced the fuse and now the gauges stay lit even with the headlights off. I also had to replace my dimmer switch, as the spring on the dimmer wheel fell apart when I removed it. What should I look into? My electrical skills are limited, so bare with me please. Thanks
what circuit and where on the circuit did you get the power from?
It is tapped into the gauge illumination circuit #13 fuse
Well that should answer your question
You tapped into the non switched side
It’s hot all the time
Doh! That would answer it then! Thanks
