I have a set of hp forward facing headers for my twin turbo build and wonder if it is necessary to run dual scavange oil pumps since the turbos sit so low. Searched but havent really found anything specific.
how low do they sit? As long as you can run a oil return that goes down
without any flat spots you`ll be fine
well if there above and like i said if you can get the lines downward in a continous
pattern you should be good to go
Ok thanks very much any particular spot im assuming to weld in 2 bungs on the pan as to have seperat oil return for both turbos. and is there a better spot on the pan to avoid frothing of the oil back into the line.
Also wondeing wouldnt the oil pan create a small amount of vaccumm to suck the oil back down just wondering.
