I have a couple t-3's (.63 exhaust A/R) that i want to put on my 94 gt. i am wondering at what rpm would i reach full boost with basicly a stock motor and 3 in. exhaust. i dont want to sneeze and have the car make 10 psi of boost, so im wondering what rpm others see boost at.
thanks guys
I have those same turbos on my car, I see full boost by 3,000 RPM. I don't think you would need 3" exhaust. I only run 2.5" all the way back.
Jeremy
P. Mussin
do the turbos choke off your performance above 5000 rpm or not? also what is your 10 sec recipe?
thanks
levi
The T3's with the .63 housings pull right to 5,800 RPM's. here is my set-up:
306 (9:1)
E-303
GT40-heads, iron, O-ringed
Cobra intake
42lb Lucas injectors
65mm TB
Kirban reg
75mm Pro-M
2 T3's (.60/.63)
NO INTERCOOLER
TransKing rollerized C4, full man VB W/ brake
3,300 stall
3.27 gear
3,600lbs
450 rwhp/ 527rwtq @ 12psi, 10.92 @ 123 on Drag Radials
Jeremy
