All things being equal in setup what power gains would be expected by switching from TW170 heads to AFR 205's ? The TW170's are 1262 gasket matched and tapered upwards while the AFR's are the #1450 CNC ported from manufaturer. Current setup is in sig.
Discussion Starter #2
I will be changing intake to a Victor Jr. that should make power from 3500-7500 rpm's
Current Cam:
Advertised Duration (Int/Exh): 276/282
Duration @ .050 (Int/Exh): 241/249
Gross Valve Lift (Int/Exh): .554/.576
LSA/ICL: 110/106
Valve Lash (Int/Exh): .016/.016
RPM Range: 2600-6800
New Cam:
Advertised Duration (Int/Exh): 290/298
Duration @ .050 (Int/Exh): 257/265
Gross Valve Lift (Int/Exh): .600/.624
LSA/ICL: 110/106
RPM Range: 3000-7200
I have almost equal to what you have on cam [email protected] and .568 lift with the Air Gap dual plane Edelbrock manifold and mine made 525hp max at 5800 I have the AFR heads I was a little disappointed cause I thought 600hp was within reach,was told to get a cam with 259 or higher @ .050 and I should be there. Anyway I don't race it only street driven so it's fine and very easy to drive
With the proper cam and induction on a 408 the 170tw heads will go very low 10's at 3150 lb
I had that combo 10 years ago. Flowtech Induction was responsible for the design of that engine
Tim
I just did several upgrades to my car, and one of them was going from a 70cc Edelbrock Victor ported head to a 65cc AFR 220cc Eliminator competition cnc'd head. Should be done with everything this week to get some results.
mark
