1 - 9 of 9 Posts
I have a 94 gt with a s trim at 8 psi right now with 42lb bosch injectors and a walbro 255 fuel pump I have to pull the motor out because its burning oil pretty bad and planning on getting it bored to a 306 and putting some forged pistons but leave the rods and crank , what I'm wondering is do I have enough fuel pump and injector to run a on3 turbo to around 10 psi or whatever to get me around that 425-450 rwhp I will probably also be putting a cobra or gt40 intake, I also don't really want to max my duty cycle on the injectors either.
Just curious if I have enough fuel for it
thanks
assume the fuel pump is boost friendly. if so youll be fine with the 42's for now
im looking for power and its a pain to intercool the supercharger so I thought while it was out id put a turbo in and get some more power outve it
Sounds exactly like my situation. I had a s-trim pushing 12lbs on my car for 2+ years, and 9 months or so prior to that on a different car. I just sold the blower and bought a on3 kit, still saving up for the little odds and ends.. need a MAF, blanket, header wrap, new plugs, oil/filter, oil filter relocation kit definitely a few other things I'm forgetting right now.. and while it's taken apart for the turbo install I'm waiting to afford to buy a new timing chain set and water pump before the install even begins.
I have a Walbro 255lph, green top 42lb injectors, kirban afpr. Will remain a stock head/cam car, already has an explorer intake on it.
Bosch 42's with stock lines and rails safely 480-500 Rwhp full fuel system will give more head room, we usually just go 60's and be done with similar combo and tuning.
Thanks.
id say if you had to buy injectors to get 60's, but id run the 42's since you have them. thats what ill be doing also
1 - 9 of 9 Posts
