1 - 13 of 13 Posts
Want to know the difference I would experience using a t76gts over my mp t70? The mp I have has a .68 a/r on it
Sent from my PC36100 using Tapatalk
stock short block custom hci from ed curtis.
185cc tw heads cncd, fully ported victor 5.0 efi, high lift low duration cam 112lsa
3.73s, built tko600
um you'll prolly pick up anywhere from 25-75 depending on several different things, but i can tell you for sure you go digging for big #'s on the dyno or single digits at the strip and you can count on saying goodbye to that stock block and hello to a boss or a dart unit. be careful and have fun. but if it were me, i'd stay with the mp70 that's what i got and it's awesome your choice i just think a 76 is overkill for your combo - jimmy
oh and what ar is the turbine side of that 76? and what trim? - jimmy
once it spools it should make some power but that's the thing, once it spools. awfully big for a stock cid 302. jmo though. - jimmy
Forget it bigger issue is what I am going to do trans wise. Either going auto or t56 for the double overdrive
i'm still running my stock t-5 with no issues at all just make sure you have good suspension and a reasonable clutch in there. no sintered iron, no pucks, just a plain old organic clutch with a good pressure plate and it'll live forever.
x2 !! my stock T-5 made it 3 years with the turbo and its still going strong but like said above..... I run a autozone stock replacement clutch... Im on my 3rd one lol but better then being on my 3rd T-5. clutch was free.. warranty for life lol
Discussion Starter #13
eh i have a built tko600 just hate the trans. i may give it one more try.
i just received my turbo kit and it did not come with a tial 44 wg, came with a turbo concepts doesnt say what size.
Any of you guys use them will it be good for this set up or will i have boost creep?
1 - 13 of 13 Posts
