1 - 13 of 13 Posts
I'm looking to buy my first turbo for a dart block 347 which turbo will be better? a pte7675 cea turbo with a .96 a/r or a Borg Warner s400sx4-80mm aka s480 with a 1.25 a/r which one will make more power?
We really need to know a little bit more about the combo. Is it a manual transmission or an auto? What are you going to use it for, ie drag strip, road course, street cruiser, daily driver? What are your goals for HP?
The S480 will make more power than the 7675, but won't be as responsive. But it really more depends on the car and what you want it to do.
It will be a street/strip car it's a manual now but will be going auto I just don't want to have to but everything over again
How much is your power goal?
I think the 76 will work better with the 5-speed
S480 will make more power and be faster with an auto with a transbrake in it. That's what I would run if you care more about what it runs at the track vs how it spools on the street.
PTE released at SEMA the Gen 2 7675.
That thing is going to stir things up!!!
I'm going to run the Borg Warner S400SX3 -80mm part#179180
Its a T4 based turbo, 80mm in and about 82mm out..
If a was to buy a new turbo again it would be the precision 8891
I'm manual trans, T56 magnum
This is what I would do as well. Very Bad A$$ Turbo
I can already see it being banned in sanctioned classes. It's going to set the standard for all t-4 based turbos.
1 - 13 of 13 Posts
