1 - 8 of 8 Posts
I've researched and searched but i havent found any answers.
Does having the wastegate only on the crossover cause boost creep? All the kits I have seen have the wastegate only one side of the header not at the where they merge and go in to the turbo.
Are B and G kits any good? Mainly the hotside?
B&G are nice kits....and yes I've got mine on the crossover and it works fine. Check out ponydown kits as I think they have them on the crossover too. By the way if your looking theres a sweet deal on a ponydown hotside and MP70 on turbomustangs.com
Yea go to the turbo for sale section over there and you should see it. If I remember correctly it was a pretty good deal. I have a pony down kit and have no issues with boostcreep with the placement of the wastegate. From what Ive seen the b&g kits sem to be pretty good. My ponydown kit is pretty decent but I do wish I did a DIY kit often.
Yes and no.
It only seems to become more of an issue when you get into higher
boost levels .... like 15-20+psi and exhaust flows demand a "perfect" design.
Have seen many turbo kits built like you are describing and they all seem
to work ok at modest boost levels.
1 - 8 of 8 Posts
