Hey guys anyone have a descriptive turbo install with pics on a 94-95 5.0 just curious it would make my turbo install alot easier. thanks
Also what are the best plugs to run with 8lbs of boost on stock e7 heads just dont want any blowout.
And after i do my turbo install will i be ok to drive it to my tuner around 40 miles will be running 42lb injectors with matching mass air also what should i make my fuel pressure
Stock Motorcraft plugs gaped to .030" will work great, I'm running them on a 306 w/ e7's and anywhere from 8-16psi boost.
Also, you should be fine without a tune. I've been running 42's w/ a matching 75mm MAF for almost 2yrs w/out a tune (Megasquirt's coming over the winter), just make sure you take some timing out of it. I run 6º base spout out, then I put the spout back in and hold on.
Cal
