This turbocharger features a T04E 60 Trim compressor. Looking for more power? Search no more. The tried-and-true combination of T04E series allows you to achieve big power while retaining compact packaging. Turbonetics T04E compressor wheels are extremely effective on high pressure applications. Match it with Turbonetics Patented Ceramic Ball Bearing and you get a monster result! With its larger compressor housing (compared to T04B) and 3” compressor inlet, T04E is able to deliver the power you desire. The F1-62 turbine wheel is included in this unit. Turbonetics exclusive F1-series turbine wheels feature a 10-blade design and tall tip height configuration to maximize the exhaust gas energy and keep back pressure low. This turbocharger also feature Turbonetics patented Ceramic Ball Bearing system. Turbonetics exclusive design is made with almost indestructible silicone-nitride ceramic balls. and it has the option of being water cooled too
First time turbo leaving the bottle scene im totaly turbo dumb
how would this do on a 306 perfomer rpm heads and intake e303 75 mm throttle body 5 speed street car thanks
