im building some headers for the 4v. i picked 1 3/4" thinking about volume flow pushing a 92mm turbine with a 27cm housing. obviously im wrong about the size. so i guess im going to make log style manifolds.
any good suggestions. final output will be 1200 or so crank hp. its about track times not dyno numbers.
ill post up pics as i make them. i think im still going with the 1 3/4 primaries, but they will be stubs going into a stepping log. final step will be 2.5" so there wont be a collector.
i guess i could use the 1 3/4" "ovals to round" i've made and weld a 1 5/8"'' pipe in it and still 'log' the manifold.
i thought i had it all figured and i was told they are wrong. so its back to the drawing board a little.
