1 - 16 of 16 Posts
ok I have looked a little. My question is how much boost can I run with a set of shorties turned around with the ball and socket joint before it starts leaking????
thanks Luke
Friend of mine has the older Cartech Fox kits, the passenger side was a ball and socket shorty header never has any problems.
as long as it's aligned and tightened properly, you won't have any problems.
run as much boost as the motor can take, it's not gonna leak because of that. however, backpressure could find an escape route through it if it's the weakest sealing point in the system. but again, put it together properly and you won't have any issues
thanks guys.
What about fitment?? I saw where some one used the flowtech headers and they hit the motor mount. Has anyone tried this before? If so what headers did you use?
I think I may do that but I need to know what fits first. BBK-1
WHITEMACH you running BBK also? are they equal or just shorties
You don't need equals. Just go with unequal length shorties. I machined my own V-bands, but you can buy them and convert as said above. The BBK's have been the most popular header for the diy kits. Do some reasearch on turbomustangs.com They have a dedicated DIY forum.
Discussion Starter #13
Thanks for the info guys
Luke
Stock work fine. I just welded a pipe and T3 flange on em.
Erich
Discussion Starter #16
alright but stock won't cut it for me.
Thanks Luke
1 - 16 of 16 Posts
