Anyone running a 408 with a turbo? Looking for dyno graphs to see how much torque and hp they are making and how the torque comes in.
Ideally it will run like a 408 then come onto boost limiting tq to 500-600 but make 750-900hp. Suggestions are welcomed never ran/built a boosted motor. And not even sure if this is possible while keeping it on the street and making decent power before boost comes on. Motor will see a lot of street use as well as some track track use. (weekend warrior)
(not sure if the vortech V7 YSi is a better option, hence the double thread, if there is a problem please delete)
i have a 410w put out 957rwhp with 18lbs of boost with a supercharger not a turbo afr 225 heads custom cam 9:5:1 compression and vic jr intake and a 750 quick fuel blow thru carb but im kinda interested in ur question now i now have a 88mm turbo high ports heads man of war intake and a carb shop blow thru i havent ran this set up yet
