1 - 8 of 8 Posts
Looking at going turbo a 90's mustang. I'm thinking using an in-line mass air, a FMU, and that's about it. Or is there anyway I can have it tuned?
Thanks.
you can have a chip burned for it
Ditch the FMU idea and just get a big enough fuel systym !!
I run a PMAS pro tube/42#ers and a 255 high pressure intank pump.
I running with NO tune but I got lucky ! I suggest a dyno tune
what HP are looking to hit??
I run 42lb, 255 in tank, and pro tube maf. I use a tweecer for tuning. I tried just running the stock computer and locking timing, playing with fuel psi, etc. I didn't like it. Some are lucky, some aren't.
Do your self a favor and get it tuned by you or someone else.
same exact setup but I got lucky lol. dont even lock timing, just run 8* base
how is the tweecer? is it as complex as it seems/everyone says? The car has run great for 2 years but I know it could be better cruise wise. The tweecer is about the same as a dyno tune Im just scared to jump as I can barely use a computer lol
Alot of people are using the Quarterhorse now. It's datalogging rate is much faster than twEECer and it has the ability to make changes while the car is running.
Luke
Im very fresh to the EFI scene, not to mention the tuning end of things, so im going to get my feet wet on a SDS system for a bit, see how well i grasp things. Lotsa guys seem to be liking it, so we shall see. I needed to buy a maf, and eec anyways, and ill be into this sds for basically the same coin. Just made sense for me.
Coxy
If you don't want to get into tuning it yourself. Get rid of the FMU and have a chip burned on the dyno.
1 - 8 of 8 Posts
