1 - 11 of 11 Posts
I'm looking at getting on3 kit but a local tuner said its almost 1000 bucks to burn a chip and tune it. I'm thinking of running low boost to save the trans. They said the msd/vortech just spikes the fuel pressure and is a caveman way of doing things. I don't really care as long as it works. This is my 3rd car so it will be rarely driven. Just looking to have some fun.
88 5.0 aod
Msd box works with timing. I personally never used one but have seen good results from people on net. What your thinking about with fuel is the vortech FMU. It's a boost referenced fuel pressure regular the ups the pressure when boost comes in , I had one on my last car, I don't recommend you get that.
Sent from my brain.
I use the boost timing master from a old vortech kit! Running 15 degrees base timing and let the btm pull timming out! It works pretty good! As for the fmu I would stay away from that. Just get u a adjustable regulator and a wide band to get the a/f good.
Alright. I already have a brand new wide band. Maybe after being all said and done dyno tuning is the same amount of money
most guys regularly charge 5-600 to tune a turbochatged car including burning a chip. Id look elsewhere
sorry for jacking the thread. I have an areomotive adj FPR that references boost (rising rate). . . are you guys saying not to use that?
The Anderson PMS is the way to go , uses a gm map sensor to pull out timing and a the tables are adjustable and it works great , no need to burn new chips and it's plug n play ......rev limiter, digital readings on intake air temp/timing/boost/engine temp .....
1 - 11 of 11 Posts
