1 - 1 of 1 Posts
i have a sct chip in my car the problem is under cold or warm start i have to push the gas pedal down to start also when i turn on the a/c the car wants to shut off and last but not least the idle would hang so the guy put a restrictor in the tube that goes from the the idle air control module to the
supercharger tube now the idle drops down take the restrictor out and the idle hangs for about 3 seconds he said the problem with the start was that
i have to pulse the injectors cause they are 65lbs. does this seem right i need some help.
1 - 1 of 1 Posts
