1 - 10 of 10 Posts
lookin to install a tubular k member, which one? I have heard some bad stories about cheap ones. Any input will help. If u use a tub k member, will u have to change the a arms?
Try using the search feature. We've had one or two topics per day on this subject for a while. I got the full D&D drag set up from http://www.jdsperformance.com and I love it. You don't have to get the A-arms with most of them, but once you see that K under your car, you'll want to. Anyway, try a search on K member and see what comes up.
Kenny Brown has a strong looking piece, with decent geometry ($600?). You can use the stock control arms, but you gotta go to coil-overs.
Maximum Motorsports will have theirs out in the new year... they'll allow the stock control arms & springs.
Hal/QA1 allows the stock arms, and there's a removable spring perch option as well. It's kinda lightweight, and not as beefie though (similar to most of the other products).
AJE (Anthony Jones Engineering) makes the Y2k and I've heard really good things about them as far as fit and header clearance but most k-members will work fine ifyou build a run-of -the- mill combo. Some minor "tweaking " is always necessary if you plan on running 1 7/8" or larger headers I would just stick with the cheaper D&D from Jd's that evlgt told you about. I have that setup on my car and have no complaints and I run 2" headers. They required a little bit of fine tuning to make them fit.
I run the AJE setup. Most of the Racers I had talked to said that they had alot of problems with some of the other kits with header clearance when they worked on cars between rounds. I was told they had the most header clearance. I installed the kit and was thoroughly impressed how well everything fit. No grinding, modification and everything bolted on perfectly.
It depends on what you want.
You really have about 3 kinds of K members.
You have ones that are just lighter than stock, no relocation of suspension geometry points. This is the majority of them like D&D, GP, HAL
Then you have the drag strip ones that stress super light weight and improved header clearance: AJE
Then you have ones for all out cornering that move the A arms forward 1" to increase the wheelbase and at a different angle for brake dive, etc : Griggs.
Then you have the MM one that is not released. Also Wolverine has something similar that will work with stock, coilovers, and SLA. But there will not be a lot of weight savings there. Again, more suspension oriented by removing the strut and going coilover shock.
I'll say again, what ever you get don't get a Gound Pounder. I crushed the passenger side of mine and never could get my alignment correct. Many other problems with fit. Finally bought a Hal to replace it. Had some fit problems but nothing that couldn't be fixed.
1 - 10 of 10 Posts
