Well im currently in the market for a tubular front k member. Toi my understanding AJE is the only company who seels a K member with Lsz motor mounts to put in a lsx based motor. Im wondering if the motor mounts from aje will fit on any k member to save money. Its only 350 new plus 69 for motor mounts but i have a budy with a upr for 200, so i want to no if itll work and save me a couple hundred bux. :confused:
the crossmember has removable mounts and can replaced for use with any motor combo...and you will get more response if you put this in the mixed breed section on here
The mounts are not interchangable between K member manufacturers. The AJE mounts will work only on the AJE univeral engine k member. It's a very nice piece if you change engine combo's alot
Don't forget the upper spring mounts if you aren't going coilover. $55 extra from AJE.
its $350 for the k-member w/the mounts. there is a guy on here that'll do around $360 shipped for the k-member with the ls1 mounts.
