1 - 20 of 23 Posts
New, never used trick flow valve springs, valve locks, and retainers. The springs are single springs with dampers. 1.470" in diameter, 110lbs @ 1.800" installed, 305lbs @ 1.260" open, lift up to .540". Part #TFS-16514. Retainers are 7° x 1.500" o.d. Also included are Trick Flow hardened steel 7° valve locks. Part #TFS-51400423. Asking 110 Shipped.
Are the locks and retainers identical? If they are, this is likely a take off from the base single springEd twister wedge head and not the kit for e7 heads with differing valve tip lengths between intake and exhaust.
Ahhh I see Rob. The springs came with the twisted wedge heads that I had purchased, so that is the most likely case. Thank you for the information.
so this is a no go on e7 heads?
I dont believe that you'll have to machine the heads. But as Rob stated, since these are a take off twisted wedge heads, the installed height won't be correct for the e7 heads. So you would need to either get different locks or shim the rocker arms.
1 - 20 of 23 Posts
