were are you guys mounting the trans cooler on a turbo car with a on 3 exhaust? would like to mount it somewhere under the car but dont see any place safe.also dont want them close to exhaust. does anyone have pics of how and where they have put them?
I put my power steering cooler in the fender. There's about zero air flow, but wasn't too worried.
Powerglide doesn't heat much on a street car. But I found an equally bad spot for the cooler anyway. It's on the passenger side/ bottom of the pic.
So there's a couple less than stellar ideas.
Past that, if you run a fan you should be able to get away with just about anywhere.
I located mine in front of the drivers side tire:
ks
Mine is similar to Kevin's, but horizontally:
