1 - 10 of 10 Posts
I am wanting to trade my setup for a coyote swap for a foxbody. I have a lot of money and nice parts in this setup and it is all fresh. Here's what I have. Dart 9.5 block 408w. 4340 forged crank, eagle 4340 H beams, mahle -22cc dish pistons. Neutral balanced crank. ARP hardware in bottom end. Custom ground hydraulic roller cam by cam motion for the turbo setup. The heads are trickflow 225 highport R cnc heads. 72cc chambers they are fresh from the machine shop with a fresh valve job and have solid roller springs. The motor comes with a fluidamper balancer, fidanza aluminum flywheel, rebuilt melling oil pump with a very beefy oil pump driveshaft, moroso 7 qt oil pan for fox. Precision PT101mm t5 tangial flange turbo. 1.00 AR. Rated to 2100hp. Comes with full hot side, headers cross overs, and 5" downpipe. The motor is currently at a very reputable machine shop getting a full rebuild with all new clevite rod and main bearings. Dart cam bearings. Total seal AP rings for boost. Everything will be checked. Will look at reasonable offers for this but I'd really like to trade for a coyote swap. Thanks for reading post any comments or questions, I'm sure I left a lot out but it is a lot of parts. Will post pictures below.
1 - 10 of 10 Posts
