1 - 16 of 16 Posts
FIRST OFF THANKS TO KEVIN AT BASELINE SUSPENSIONS!!!!!!!!!!!!! THE SUSPENSION WORKS LIKE CRAZY!!!!
i had a autoweld chassis arb in my car that was junk!!
i have basline uppers so i went with a baseline ARB also.
before the baseline arb the car was unmanagable. it never made a clean 1/8 or 1/4 pass. the body would twist so bad at launch the car would never settle down and go straight.
heres the update!!!
i went to Sooner Motorplex in lawton,ok to run in the 6.40 1/8 class. i had to use the baby pills and let off early to run the number.
first pass i ran it through to see where i was at. it was in the heat! car ran better every pass.
1st qual 1.32 60' 3.93 330' 6.13 @ 110.86 http://www.youtube.com/watch?v=Rul5W-U05JY
2nd qual 1.33 60' 3.93 330' 6.34 @ 88.76 http://www.youtube.com/watch?v=sK2vKXMoSuA
1st elim 1.29 60' 3.94 330' 6.58 @ 76.36 http://www.youtube.com/watch?v=0B9Zayr_LMc
2nd elim 1.26 60' 3.85 330' 6.50 @ 81.71 http://www.youtube.com/watch?v=thRuGKNNfqg
3rd elim 1.27 60' 3.85 330' 6.46 @ 80.21 http://www.youtube.com/watch?v=pgSvQHj76xo
very nice man... glad to see Kevin's stuff working for you.
i hope it does for me too
set it up like he says and it should!
awsome 60ft..
Whats up with your MPH, 110 all the way down to 88. It doesn't sound like you are lifting until after you cross the traps.
Car hooks awesome, I can't wait to put Kevins uppers and ARB on my car.
it slowed down to 76 on one pass. you hear the other cars. i was lettin off at the 330' mark.
trevnut,
Nice 60's! what does the rest of your suspension consist of? Tires? Are you using the weld inbetween the frame rails ARB or the one that welds/bolts to the trunk floor? thanks...
Troy
Do you have a lean hole? It looked like something was getting hot under the car???? Glowing or something??????
Right bank...
its the light gleaming off yhe polished stainless muffler
Discussion Starter #12
trevnut,
Troy
front is upr k-member and a-arms, strange 10-way struts with 14" 175lb coilovers (i had 14" 130lb but the front sat to low)
in the rear i have baseline pro-launch 2 uppers, baseline trac-locator, custom made dbl adj lowers, coilovers, and baseline ARB # 3
Discussion Starter #13
That's the way I want my car to 60' and it will as soon as I get off my ass and make a couple of changes. What gears do you have?
Discussion Starter #15
3.73's with 28's
we are very similar... i have Tokico 5-way drags up front, but same K and same springs
out back i have Pro-launch 2's, ARB 2, Track locator, LCA 1, but no coilovers. Im on stock GT springs and Tokico 5-ways
hope it works well as a combo. If not... i guess coil-overs will be soon behind
1 - 16 of 16 Posts
