I've been searching and cannot find the torque down specifications for the sway bar brackets (fox)...can anyone help?
Thanks,
Eric
Damn, missed one...
Engine
Alternator Bracket to Block bolt 12-18 Lbs.-Ft.
Alternator Adjustment Arm to Block bolt 12-18 Lbs.-Ft.
Alternator Adjustment Arm to Alt. adj bolt 24-40 Lbs.-Ft.
Camshaft Sprocket gear to Camshaft bolt 40-45 Lbs.-Ft.
Camshaft Thrust Plate to Block bolt 9-12 Lbs.-Ft.
Connecting Rod nut -- 5.0L 19-24 Lbs.-Ft.
Cylinder Front Cover bolt 12-18 Lbs.-Ft.
Cylinder Head bolt (first step) 55-65 Lbs.-Ft.
Cylinder Head bolt (second step) 65-72 Lbs.-Ft.
Damper to Crankshaft bolt 70-90 Lbs.-Ft.
Distributor Hold down bolt 18-26 Lbs.-Ft.
EGR Valve to Spacer Intake Manifold 12-18 Lbs.-Ft.
Exhaust Manifold to Cylinder Head bolt 18-24 Lbs.-Ft.
Fan to Water Pump hub bolt 12-18 Lbs.-Ft.
Flywheel to crankshaft bolt 75-85 Lbs.-Ft.
Intake Manifold to Cylinder Head 23-25 Lbs.-Ft.
Main Bearing Cap -- bolt 5.0L 60-70 Lbs.-Ft.
Oil filter insert to Block adapter bolt 20-30 Lbs.-Ft.
Oil Pan Drain Plug 15-25 Lbs.-Ft.
Oil Pan to Block - bolt 9-11 Lbs.-Ft.
Oil Pump to Block - bolt 22-32 Lbs.-Ft.
Oil Inlet Tube to main Bearing Cap - nut 22-32 Lbs.-Ft.
Pulley to Damper Bolt 35-50 Lbs.-Ft.
Rocker arm Fulcrum Bolt to Cylinder Head 18-25 Lbs.-Ft.
Spark Plug to Cylinder Head 10-15 Lbs.-Ft.
Thermactor Pump Bracket to Block bolt 30-45 Lbs.-Ft.
Thermactor Pump Pivot bolt 22-32 Lbs.-Ft.
Thermactor Pump Adjustment Arm to Pump 22-32 Lbs.-Ft.
Thermactor Pump Pulley to Pump Hub 130-180 Lbs.-In.
Valve Cover bolts 3-5 Lbs.-Ft.
Vacuum Fitting/Plugs to Intake Manifold 6-10 Lbs.-Ft.
w/ Teflon Tape
Water Outlet Housing Bolt 9-12 Lbs.-Ft.
Water Pump to Block Front Cover bolt 12-18 Lbs.-Ft.
Upper to Lower Intake Manifold bolts 15-22 Lbs.-Ft.
Throttle Body to Upper Intake 12-18 Lbs.-Ft.
Air Bypass Valve to Throttle Body 71-105 Lbs.-In.
Throttle Position Sensor to Throttle Body 14-16 Lbs.-In.
Fuel Pressure Regulator to Fuel Rail Assembly 70-105 Lbs.-In.
Fuel Rail Assembly to Intake Manifold 70-105 Lbs.-In.
Throttle Cable Bracket to Manifold 8-10 Lbs.-Ft.
LOL....well this is still very good info to have on hand.
So far, I torque them down to 40 lbs.-Ft
-Eric
