1 - 11 of 11 Posts
they work great and allows people to retain the stock motor mounts. find one with a shock absorber on it. if you already have solid mounts or even polyurethane, then i wouldnt bother with it though unless you plan on reinstalling the stock mounts
i have mine on the driver side mounted to the top on the sway bar bushing mount. it bolts directly to my driver side head. i have a tubular k member and im not running a sway bar just using the sway bar mount.
i have one similar to this
here are a few pics
it makes it so the motor doesnt torque when you hit the accelerator. so i would assume it would help. every little bit helps right.
it helps transfer power straight to the wheels quicker. So yes it could improve 60ft times. Its just like adding solid mounts but without the teeth rattling vibrations
1 - 11 of 11 Posts
