1 - 14 of 14 Posts
I am getting closer to pulling the trigger on a Torque Arm and it seems that no matter what you do to a car there is always one or more unintended consequences. The most recent thing that I have thought of is that I wonder if the increased rear grip caused the LSD to go out quicker and need rebuilt more often. Any thoughts or experience out there?
Super Moderator
Not a concern.
It's actually LESS of a concern if your PHB connects to the axle on the passenger side.
I believe that my MM PHB connects on the DS.
The MM torque arm connects to where the vibration dampener on the axle housing is, more or less. Not sure about the diff, but why not get a Torsen diff? No clutches to rebuild.
This is a first for me to hear, but I think it wouldnt have anything to do with the placement of the TA or even how the PHB mounts (driver or passenger sides). Are you sure that the both rear tires have the same roll out's? Are you doing John Force burn outs every stop light or Are you driving in circles all day long? How much and how soon are you rebuilding the LSD units? If the PHB or TA is causing the LSD to wear out, then they must be doing their intended jobs (by making the LSD slip, and not causing either tire to break loose). And if it is actually just the fact that the LSD are wearing out prematurally then look into doing a TrueTrac (the units that have the worm gears).
And I think that for the street, nothing beats a good and properly installed TA and PHB from Maxi.
Also, is the oil level in the diff correct?
I guess my thought is that with soooo much more rear grip the clutches would experience more abuse because the tires are less likely to lose grip and spin. It's the same idea that sticky rear tires cause trans/clutch abuse.
If the clutches in the LSD aren't slipping/spinning....then there is less wear. Kind of like a slipping trans produces more heat/quicker death.
More rear grip could make them slip where before the tires would just spin.
The only way the clutches wear out is when one wheel is turning faster than the other. When both wheels are turning the same speed(pure grip), the whole unit is rotating as one with zero friction between the plats/discs.
Maybe i'm failing to see your ideology on this subject... :confused:
I think he is just wondering if MORE rear grip will cause the LSD to wear out faster, therefore, while he's got the car at the shop getting the TA welding done, should he get a new or repack the LSD.
I think most people just wait til it wears out, then do it. I'm also thinking that I don't remember anyone saying they put a TA in and now it's blowing through LSDs...
The TA articulates better and puts down power better than the OE setup. I don't see how a faster wearing clutch type LSD would even be in the equation. Hell, i'd say a plain old open rear diff would put power down BETTER with the added grip of the TA.
I wish he would just go ahead and buy it, I'm ready to drive it :rofl:
Discussion Starter #14
1 - 14 of 14 Posts
