1 - 13 of 13 Posts
Ok I got my car back together took it on the road and opend it up and it start bucking let off the gas and runs fine drives fine it is a 306 tfs heads cam intake on3 kit aeromotive complete fuel system
What is your spark plug gap set at?
Sounds lean...Or too much timing....
It runs fine on the freeway and just normal driving but when I start getting into it the fuel pressure starts to rise then drops around 20psi
shtty fuel pump
vac leaks
What pump do you have on the car? Make sure electrical connections to the pump are good as well.
If your using the a- motive fuel filters, take them apart and check them.We've seen some cars lately that the filters are getting plugged up.Evidently the ethanol and the adhesives in the filters don't mix.The adhesive in the canister gets eaten by the gas then plugs the filter.
1 - 13 of 13 Posts
