I need to replace the front struts on my 97 saleen convertible,
what would you guys suggest, Koni or Tokico struts?
I would like it to work with the Saleen springs.
thanks,
hennie
I have the tocikos and I think they're great, there is quite a bit of difference between the stiffness settings. If you have the money though, you should probably go with the konis. Hope this helps.
-J
Bilstein
Do you guys know what they are asking for a bilstein set struts and shocks.
as I will most likely go for the bilsteins.
thanks,
Hennie
Another good Shock is the Edlebrock IAS it is made by Bilstein with a different valve in it. I have them and they work really well. They have a nice ride but when you get aggressive they respond.
About 550.00 front and rear
