1 - 12 of 12 Posts
What do you mean running through your engine? Do you mean running too rich?
Carb or FI
I have the same problem on my carbed 351w right now. I bought jets to fix the problem but its been rainin all day. You should probably check your fuel pressure. Maybe some will read this and help you out. Good luck.
thats a good idea...i thought maybe i was in need of just a good tune-up or somthing, but i dont know....as soon as it clears up, ill check to see if i can find anything...
any other ideas??
injector stuck open
clogged maf sensor
dirty air cleaner
vacuum leaks
fouled plug
bad plug wires
cracked or tracked dist cap
yeah i found out there was just a vaccume line not plugged in that left a regulator open...i plugged it back up, and works like new...thanks for the suggestions
1 - 12 of 12 Posts
