1 - 8 of 8 Posts
Hi,
I just started building my 95 GT. Stock bottom end with 22k miles. I had a 1998 GT with a diy kit and stock engine and went 11.70.
Plan is:
-Holley Systemax Intake, F Cam,1.7 RR
-Heads- Thinking Edelbrock Perfromers
-Shorty Header DIY kit with MP 76mm Q Trim, Intercooler, JGS Wastegate etc...
-340 intank pump, Stock lines,80 lb injectors, SCT MAF, SCT Tune
- Slicks, Upper and Lower Control Arms, Lakewood Shocks and Struts and 4cyl Fromt Springs
- t5 with center force clutch
My car is full weight at this time.
I have not bought parts yet, so please critique my combo.
What Hp number should get me around a 10.7 pass and can I make that on my combo?
Thank you!
Tom
Will an otherwise stock v6 mustang 4r70w with a valve body and a big cooler hold up to it?
So my main concern is head choice. I know it doesn't take a lot to get to the level of risking the block- so does this mean I should go cheap - like new Gt40 or should I look at like twisted wedge heads?
At that power level, the stock bottom end will be a ticking time bomb depending on how often it is raced. Also, the F cam will make power but there are better alternatives. Lastly, the t-5, it's rated at 330 lb.ft. If you are making between 500-550 rwhp, from experience, both the t-5 & stock bottom will break. I'm not saying it can't be done, it absolutely can, I did it, but after 2 blocks & 2 t-5's, I decided to spend the extra $$ and go Dart & TKO600.
Best of luck!
P.
1 - 8 of 8 Posts
