What afrs should i see, before boost? And transitioning into boost?
Say at cruise speed,mash petal 1/2 throttle? No boost on gauge.
And
At cruise, mash it 3/4, mabey @ 1-2 psi on gauge, what afr?
Discussion Starter #2
Will someone share with me what your wideband reads at half and 3/4 throttle?
Just wanting an idea
if its going into boost and its not full throttle should be 12.5 and under. cruising at highway speed 13.5-14.5 WOT 11.0-11.7 from what i have read but timing plays a big roll too
This will be very dependent with the tuning? I like my turbo tunes to be a little richer part throttle (1/2) since it will be into boost, 12.5-11.9 this is also a question of load as well, there are several variables when calibrating. what you don't want is 14.5 at half throttle when your in boost, whole different concept then a SC setup.
Thanks, Chris.
Thank you
