I would think the tensioners would fail before the chains.
Are you getting any driveability issues, or do inquiring minds want to know?
I agree that the timing chains will last a long time. If there is any slack in the chains it is due to the tensioners being weak. But why are you wanting to replace yours?
Don't want to replace it. I hope it lasts forever. But, I'd rather give it some attention now or eventually replace it before it fails and takes out my engine innards.
I have about 60K on my 96, but I assume some folks have much more mileage on their cars and may have had some early indications of problems. I'd like to anticipate when a breakdown might occur and act beforehand.
Sorry to say, but the only way you are going to know the chains are in trouble is if you jump time. This may happen due to a bad tensioner as mentioned before, but in addition to the time jump you run the risk of ripping up a cam or crank gear.
Personally, I wouldn't worry about the chains. Now if we had belts, that would be another story.
I personall worry about alot of other things (DAILY :barf: )
