hey my cars front end sucks @ss.
instead of them setting like this I I
they set like this / \
and this one ^ points more < that way!
its wearing the hell out of my tires on the insides. a guy said it could be my tie rods worn out? :mad: :confused: :(
Super Moderator
I'm not quite following your diagrams but if you can wiggle the tie rod up and down at either end, that end is shot. If you can wiggle either wheel back and forth with your hands at 9 and 3 on the tire, one or both tie rods is shot. If it has toe'd out like this with no other suspension changes, chances are something's shot. But if it did this after you lowered the car, that's totally normal because lowering it increases negative camber and increased negative camber causes the tires to toe out until it's corrected.
to add there to MFEs response, get some J&M or MM CC plates. The rubber donut stock strut plates will not hold an alignment worth anything
