I have a brand new set of these from Scott Drake: Brand new not even opened
Item :
5R3Z-3A130-BL
By foxfir50 at 2010-09-08
Unit of Measure:
Pair
Description :
Replace your factory tie-rod with our bolt in adjusters to easily fine tune out bumpsteer that causes unwanted handling characteristics. Constructed of 7075-T6 billet aluminum adjusters with heavy-duty spherical rod ends and heat-treated high alloy steel tapered shafts. Highly recommended for lowered vehicles or modified suspensions.
$129.95 plus 10.00 shipping in the lower 48 states
We also have one of these The girdle is brand new as well...
Our cast-aluminum Differential Girdle features beefy construction to help keep your rear axle housing from distorting. Features load bolts to keep the main differential caps from walking or distorting, a fill plug to save from the hassle of having to fill from front of the rear axle housing, and features a magnetic drain plug. Includes all necessary hardware to install except gasket. Note: Not for Mustangs with IRS
139.99 plus 13.00 shipping in the lower 48 states.
