Hey guys, i have a new motor in the works and will be using a Carb manifold and converting it to EFI. My car is a 94 and currently has a 70mm TB. I am going to use an elbow on the carb manifold.
Do I buy a FOX body style TB?? or use a SN-95 style still??? are the plug in harnesses the same??
Sorry for the basic style question, I jusr don't know if the plugs are the same.
Chris
You want to use a Fox style... In addition, there are a ton of threads in the 94-95 section about converting over from the stock style. All the info you need and more...
