1 - 8 of 8 Posts
Thoughts on this turbo?
Guy says its a turbonetics 70mm. based on the little research I've done, it is not a turbonetics (I dont see turbonetics anywhere on the turbo), and eventhough it says super T70, its actually like 60.5mm not 70mm.
You turbo guru's, is this a cheapo chinese turbo? Is this thing even worth running on a mild h/c/i 302? The guy said it made 8-12lb of boost on the 302 car it came off of.
A t3 is way too small for a single build. Just because it made psi doesn't mean it makes good, efficient power. If u want a reliable, cheap turbo look at some Holsets and Garretts from diesel apps.
thanks goat, thats what I thought as well. it came with a diy setup i bought. everything else about the setup looks pretty good, all 3" tubing with tial bov and wg. My searching led me to the honda forums haha so I guess I'll try to sell it and get a real turbo.
yea i tracked it down, its from XS Power. Its up forsale on craigslist. I'll be getting a real turbo soon :)
Lots of guys are having good luck with the GT45 off of ebay. Look on TTF
1 - 8 of 8 Posts
