1 - 9 of 9 Posts
long story short....i have 455 buick motor setting around collecting dust and started thinking of putting it back in a g-body when the phone rang one of my friends called and offered me killer deal on his coupe...quick parts run down....aje k-member control arms coil over and cc kit...8.8 rear end 3.73 gear,cowl hood,weld super lites fattys and skinnys,qtr stick for a turbo trans,auto meter gauges,10 inch conv. for th,10 point comp. eng. cage,the car has very nice body and i dont see much of a problem putting the 455 in it since its not much bigger than a small block chevy and actually weighs very close also and has factory 15 degree heads on them...i'm thinking it would be a neat set up with the buick motor...so what do you guys think NEAT OR A STUPID IDEAL....
Formerly LSNotch
Hmmm I don't have any idea when it comes to Buick engines. What's the potential on those?
the good....size and weight of a small block chevy,455 cubic inches,15 degree heads from the factory,the originol hemi killer.....lol.....the bad...oiling system,expensive motors to build,not as much aftermarket support for them.....i was thinking since i already have one and it makes good power it would be a interesting project.....im going to run the exhaust out the back like factory and make it a driver....the buick motor has a great sounding cam that sounds and revs just like a small block.....
I say do it. What else you gonna do with that boat anchor? Then you'll have 2 cars that cryallday will bash you about.
Gonna make some "Mustang GS Stage1" emblems?!
lets put it in pbh so you can ride some wheelies....but if i put it in my car i'll tell hateallday it has cleveland heads on it so he wont lose no sleep....lol
I'll be riding wheelies soon enough. I'm making some changes to the turd.
The only thing about those Olds / Buick blocks is they have Siamesed cylinders in the two center positions on each bank. They can have over heating issues and suffer from bore distortion / egg shaping.
Rebuilding with boring the cylinders isn't good as there is very little material to work with in stock form.
1 - 9 of 9 Posts
