what kind of 1/4 mile times from a 351 with afr 185 heads and a decent cam maybe a 76mm turbo on 10-15psi?
Tens easy with supporting components. Stock CI with a 70mm and a mild trickflow topend kit make from 450-520 all day at the tire.
But you run into more problems like fuel system and big enough downpipe when you go bigger ci.
I'd hope I could make 450 rwhp on the motor I made 477 on the setup Im running on and with a few more runs I'll go 10.90s
Dont 302s make that power with a 70mm and 10-15lbs? With your setup, id think 550+ pretty easily wih good flowing heads, a good intake and a 76. I think whats going to slow you down is traction.
