Hellion Power Systems Mustang Turbo
"Devastating Power from the Eliminator"
Check out this video of the new 2011-2013 Eliminator Twin Turbo System pounding out an astonishing 1,249 rear wheel horsepower. This pull was made with 23.9 psi of boost.
(Complete System Includes 80lb/hr injectors and Programmer with Base Tune Installed)
The highly anticipated 2011-2012 Mustang GT TWIN TURBO system is finally here! As a complement to the already available single turbo system, the twin system will now be able to take your 'stang to the next level.
The top mount kit is adjustable from 5 psi to over 25 psi. A 5 psi setting will make over 600 rwhp on a bone stock car. The kit has the ability to make over 1200rwhp if a built engine is chosen.
System Includes:
• Twin Precision billet 62mm turbos. (V-band inlet for easy installation)
• Twin Turbosmart 40 mm wastegates (V-band inlet for easy installation)
• Twin Turbosmart VEE port bypass valves
• Stainless 4 into 1 tubular headers, all American made stainless piping
• Large vertical flow dual inlet intercooler
• Dual 3" downpipes (can connect to factory exhaust if desired)
System Options
Ball Bearing Upgrade
64mm Precision CEA Billet turbos (Ball Bearing Only)
67mm CEA Billet wheel turbos
Turbosmart E boost 2 boost controller
Turbosmart E boost Street boost controller
AEM wide band O2 kit
That's just insane!
GEESH! I don't know how you could even use that much power! I struggle to use my measly 600whp! Those Coyote engines are just amazing!! DROOL!!!
Jersey True Street Guy
That is damned impressive. I'm sure that kit costs some money but if you consider how nice a driving ride that will be for having that amount of power it is well worth it.
Very impressive work by Hellion.
I want one!
