1 - 13 of 13 Posts
i need a flexplate (auto tranny) for my build i called summit and they said nobody makes one .. does anyone have a company name or part number .
try jegs,i believe they carry one...
What stall coverter are you going to use ?
Best for the price is GM Part # 12621399 ($57.30 from dealer)
Complete flexplate, spacer, and bolts. Makes a glide/th350/400 a direct bolt up.
that GM part number comes with everything you need ?
Yes
If you are using a early 6.0L with the long crank, you just need a factory flexplate for a 99 6.0L 2500hd truck.
Ive yet to see a 6.0 gm flexplate crack (out of 100's), only the fbody LS1 flexplates.
I run a Meziere Billet One piece LS flexplate on mine...its about $400 from Jegs/Summit. THANK GOD it came with a motor I bought or I would never have spent the $ for such a nice piece.
i have a 6.0 i still have to verify year(where is the date code?) but it has the short crank, the flex plate is bowed in not straight. what will i need for that to go to a th400?
is this the part number i need? just trying to be 100% sure.
__________________
1 - 13 of 13 Posts
